ā2005-10-25
02:28 AM
ā2023-05-23
05:18 PM
Rubia Torres
ā2005-10-25 03:30 AM
johncassel wrote:A tip to you and everyone else: Your AC 9 installation CD has quite a few PDF files with product documentation, including David's book. If you create a folder (if it does not exist) called "Documentation" under your AC 9 program folder, and copy all of these PDF's into it - they will all show up in your Help menu and be one click away. The 6 PDF manuals that are part of the US SE9 library should also be placed into this Documentation folder to be easily at-hand.
Where can I find the PDF version of this section?
ā2005-10-25 12:13 PM
Karl wrote:International does; this is US only.
If you install the 2nd US CD (Training Guide), it does create the Documentation folder and copies the training PDF's properly. It is an installation flaw IMHO that the main installation does not install the PDFs.
ā2005-10-25 07:13 PM
Djordje wrote:Right ... I was speaking of the US version. Sorry for confusion to INT.
For all with Int version:
C:\Program Files\Graphisoft\ArchiCAD 9\Graphisoft Documentation
ā2005-10-25 07:26 PM
