Help i am new to ArchiCad and have no idea what to do
My university class recently started working on individual projects using the archicad program, whilst working on my project all my walls (exterior and interior) Became filled with black ink - not showing the actual wall and the materials, this is in the ground floor plan i have no idea what had happened please help.
2 Replies 2
Go to the Document\Set Model View\Model View Options Dialog.
In the Override Fill Display panel there are settings that could have caused this.
Please also note that Model View Options are saved with Views so when you apply a View the fills might change again. The solution to that is to check what Model View Options Combination is saved with the View and then redefine that Model View Option Combination to the fill settings you need.
Bruce
You could have also changed the pen set used. Often templates have a modelling (colour) and a printing (black and white) pen set.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
