2011-05-05
05:07 PM
2023-05-26
12:31 PM
Rubia Torres
2011-05-05 07:31 PM
2011-05-05 07:56 PM
2011-05-05 08:40 PM
2011-05-05 09:25 PM
NStocks wrote:You should be able to do this relatively easily with OBJECTiVE (if I understand your requirements correctly). I assume that once you have the correct curve in elevation, you want to further deform the shape in plan to form something like a spiral? If so, take a look at the attached image:
So I'm trying to create a steel structure (concept) that can be bent on plan (so it's basically stretchable)
I've used OBJECTiVE for a less complicated form but it needs developing. I can't seem to find a way of altering the shape in plan whilst also retaining it's vertical height etc.
2011-05-05 09:48 PM
2011-05-05 10:42 PM
NStocks wrote:You'll find that although 'Offset' stretches in one axis, you can still stretch in the other axis simply by clicking and stretching the hotspot at either end. The combination of offset and stretching can move the endpoints anywhere you like.
I've just tested the Offset and found that it moves in a fixed position. I want to be able to move it in any position...EDIT: Ideally I'd like to keep the whole structure as one piece (so around 120 metres long) would it be possible to add more nodes/hotspots to create more curves but retain curves already created?
2011-05-05 10:50 PM
NStocks wrote:The attached image shows a series of segments modelled with OBJECTiVE to form a continuous strip.
2011-05-05 11:22 PM
Ralph wrote:That image has convinced me to use OBJECTiVE for this task! (i've used OBJECTiVE on every project since starting University , I didn't think it would be easy or fast enough to use OBJECTiVE in this case, however I was wrong!)NStocks wrote:The attached image shows a series of segments modelled with OBJECTiVE to form a continuous strip.
2011-05-05 11:28 PM
