Srinivas
Help with Quoin
I need to model this window, please see the attached image.
Thank you for all your help,
Srinivas.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
2 Replies 2
if the windows are all the same i would use morph to add the quoin to a simple window, if you have several windows with different dimensions and you will use it often i would use gdl.
Srinivas
There are Several windows of different sizes, it seems Morph is the only way to go, as I couldn't find the object that does this easily. Thanks for your help.
-Srinivas
ArchiCAD Service
Mac, Windows 11
