2007-07-04
03:14 AM
2023-05-25
05:12 PM
Rubia Torres
2007-07-04 04:09 AM
2007-07-04 04:20 AM
2007-07-04 04:22 AM
2007-07-04 05:25 AM
Peter wrote:The mesh tool should be set to the "polygon" drawing method. If the "rectangle" is selected ... you can't add a point in the field of the mesh.
Place a hotspot at the intersection of the two pairs of lines and delete the lines. Select the mesh, enable the mesh tool, and
double click on a hotspot, a dialog titled "new mesh points" appears
with a switch with three options, pick " no surface fitting" which
will place the node at zero elevation.
2007-07-04 07:33 AM
2007-07-04 03:04 PM
