Help with getting walls, windows, doors to show 2nd story
Hi, I am still a beginner with ArchiCad, and I am completing a midterm for a 2 story residential home. All my walls, windows, and doors show up fine on the first floor plan. However, on my second story I can only get the walls and furniture I added to show. The walls, which are from the 1st story do not show unless the trace reference is turned on from the 1st story. Windows and doors I added to the 2nd story are not visible at all in floor plan view, however can be seen in 3d view. Any help is appreciated thanks in advance!
Eduardo Rolon
Just to check if it is something simple:
• Select walls in 1st floor or 3d.
• Open the settings and under "Floor Plan and Section"
• click on 'Show on stories" and change from "Home Story Only" to "All Relevant Stories"
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
You were absolutely right! Thank you so much!
