Help with walls behaving strangely
MAlbiston
Hi
I am a student having trouble with a wall in my house design. In 3d in the interior it is showing up the wrong colour,  skinnier than in should be, the window frames are sticking out, and there is a gap to the intersecting wall. It looks fine on the exterior, and in plan views everything is normal. In the settings it also appears to be the correct colour and thickness.  I tried adjusting the roof size as i know that sometimes makes the walls do weird things but it didn't help. Any ideas
Thanks
Is it to do with the 'Partial Structure Display' setting?
Maybe on the plan and exterior view it is set to show all.
But on the interior view it is set to show 'core only'?
MAlbiston
Hi
Thanks for your suggestion.  Turns out I just needed to move and adjoining wall 1mm!
Monique
