Help with window
Someone can help with this window?
I need to do this attached window but all the window library that I have don“t have this opening. How can I make one?
12 REPLIES 12
Djordje
Which ArchiCAD are you on?
This looks like a standard window; explore the parameters a bit - shutters should be available as accessories.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I“m working with Archicad 9, the window I have, what I need to do is the openning.
I“m sorry, my english is not that good, I was refering about the shutter.
Hi Bitoque, wich city are you from?
(ola tudo bem), are you a student?
best regards
Oi, eu estou no Algarve, e sou arquitecta.
Ola Bitoque,
talvez fosse interessante tirares um curso de archiCAD, na medida de aprofundares os teus conhecimentos e ganhares uma certa prƔtica no uso das vƔrias ferramentas, visto que serƔ dificil neste forum conseguires resolver esses vƔrios problemas.
cumprimentos
NĆ£o entendi qual a tua dificuldade, seria inserir venesianas (shutter)?
Na imagem em anexo usei a janela Double Sash (1.3Windows/Wood Plastic Windows/Casement Window) e inseri uma venesiana semelhante a que estava em teu desenho.
O mais confuso, eu acredito, seria o gradil da vidraƧa (nĆ£o sei como o chamam em Portugal). Ɖ habilitado alterando os parĆ¢metros em (Sash Frame/Sash Style) e entĆ£o defina as medidas das peƧas.
Seria isso a tua dĆŗvida?
For those who don't speak portuguese I was explaning how to add a shutter using the Double Sash window. Found in (1.3Windows/Wood Plastic Windows/Casement Window)
Then add the frames changing the parameters of that window in the Sash Frame/Sash Style list.
**[/img]
Dwight
Now, there is a language with plenty of the letter "o".
Dwight Atkinson
Dwighto... get back to work on your booko
woodster
