Learn more
Achille Pavlidis
Hexagonal grid
Is it possible to have a skewed grid in Archicad? Like a Frank Lloyd Wright hexagonal grid?
Mac OS 26.1 | AC 29.0.2 INT 3200 FULL
4 Replies 4
You can have a rotated grid. Not sure about a "Hexagonal" grid...
No hexagonal grid or a grid where the two axes are not at 90 degrees.
If I had this situation I would probably write a GDL Object to achieve that.
Achille Pavlidis
OK thanks, Laszlo
David Maudlin
Or set out a series of lines, then lock them (or put them on a locked layer). The cursor will respond to the lines' intersections.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
