Hiding exterior finishes in composite wall
I am using a composite wall. On the 1/4" floor plan I want the exterior stucco and the exterior insulation to show. Also, on the 3D model I want the exterior finishes to show. However, as a background for framing, electrical and mechanical plans I don't want these exterior finishes to show. Is there a way this can be done? Thank you.
I found the answer by searching past posts. ArchiCAD is great!
It is helpful if you solve your own question to post the solution so those playing along at home know the answer as well.
I assume you discovered 'Partial Structure Display'?
Yes. That's correct. Sorry I couldn't provide the link. Hard writing from a small tablet. Im not on my Mac at work.
