Hole in wall
This is probably very easy to do, so pardon my ignorance.
I have an existing building w/ a new addition. Existing windows (1'-0" to 10'-0") are being removed and a handrail placed inside the existing opening. I cannot get the handrail to show in 3D. I have tried changing the window to an empty window and changing it to a rectangular opening w/o luck.
please help!
5 REPLIES 5
Jere
What tool was used to create the handrail?
ArchiCAD 26; Windows 11; Intel i7-10700KF; 64GB RAM, GeForce GTX 3060
Dwight
Seems a good mystery.
At what height is the handrail?
Dwight Atkinson
Dwight
And depending on the element, have you got its 3D view enabled?
Dwight Atkinson
The top of the handrail is located @ 30" AFF.
I created the handrail using the beam tool, but i am not married to this way, I just find it the easiest method to create and edit as req'd.
OK, I changed the priority of the beam and it has appeared.
Thanks for the help
