Hot to make colums and beams look like Tree Trunks?
In preparation for my next Uni Project I want to learn how I can make standard ArchiCAD component ( beams and columns) look tree-like, as my project is located in a woodland. The project is also about sustainability so using what's already on site it worthwhile.
Would a complex profile work properly? say if I drew it on plan, it would looks like a section through a tree trunk (circular with jagged edges) but would it work like that? I'm not experience with Complex Profile (though I know a little on how they work). Can I create a new profile that will work from a 'plan' or section of a tree trunk ?
The Plan would look something like this: http://www.inkart.com/images/lineart/tree_trunk_cross_section.gif
Thank You
Steve Jepson
You can rough up your beams and colums with seo then save as new object and apply a bark material.
Have you tried the Log Details tool in ArchiCAD ?
Also, you can download .3ds logs and tweak them in ArchiCAD.
There is a progam called ArchiLog that might be of interest to you also. ?
http://www.cadgarage.com/loghoso.html
All points you mention certainly seem good ideas! Just one question the attached image, is that an ArchiCAD screenshot by any chance?
If so, it's something I can aspire to achieve.
Thank You .
Steve Jepson
http://www.turbosquid.com/3d-models/3ds-max-logs/479789
they have some free logs you might be interested in as well. this one was $9.00
