Hotfix-5 for ArchiCAD 12 (build2675)
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
Dear AC-Talkers,
Hotfix-5 is now available for INT, AUS, NZE, AUS localized versions of ArchiCAD 12. You can download the Hotfix through the Help menu/ Check for Updates command. You can find a list of fixed bugs in the Release Notes.
Gergely Kmethy
22 REPLIES 22
Erich
Bob,
No one is teamworked...and of course from the release notes:
Mac OS X Leopard (10.5) users - installation troubleshooting: The installer should run normally for the vast majority of users. If the installer cannot complete the update process, then there is likely a problem with the access permissions for the files in your ArchiCAD 12 application folder. Make sure that you are installing from an administrator account and have Read/Write permission to all files installed in the ArchiCAD folder. This includes all third party add-ons and libraries.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Stephen Dolbee
Does this update include US version?
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
"Does this update include US version?"
Based on notice from Graphy, clearly NOT.
Eduardo Rolon
But if you go Help -> Updates it will take you to the page were you can download the US version.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
rocorona
It seems the answer is NO... but there are two AUS versions...
gkmethy wrote:
Dear AC-Talkers,
Hotfix-5 is now available for INT, AUS, NZE, AUS localized versions of ArchiCAD 12...
Pretty sure one was "US" not "AUS".
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
I'm downloading my 105MB hotfix now @ 23.1 Kb per second. Come on GraphiSoft you can do better than this.
You have to tell Australians everything twice, or they won't understand.
(It's a joke)
Well it looks like I'm mostly half right.
Which is a lot better, than when I'm mostly half wrong?
Wokka
(It's a joke)
Maybe we're twice as good.....
Warwick Lloyd-Martin
3 D E N V I R O N M E N T
http://www.3de.com.au
Windows 11 Pro 64bit
ArchiCad 4.55>27 AUS
Lumion 12.5/2023
D5 Render
Rod Jurich
Or 'cos you speak NZish
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
