2006-07-28 06:05 PM
2006-07-28 06:47 PM
gkmethy wrote:
Dear Talkers,
It's time to visit the Help menu / Check for updates command to get the latest Hotfix for ArchiCAD 10 (build 966). Please check out the Release Notes for a fixed bug list.
If you are using goodie tools, you should also click to the goodies page to get the the updated versions.
2006-07-28 10:42 PM
2006-07-28 11:08 PM
2006-07-28 11:41 PM
2006-07-28 11:44 PM
2006-07-29 12:11 AM
2006-07-29 10:24 AM
archislave wrote:If your installation is Mactel already, and the updates check tells you to update, you should, unless it's a bug in the Check for updates. But to be safe, either do a full SuperDuper backup of your hard drive before, or wait until others dig ouit the problems.
So what does that mean? When I check for updates on the Macbook is says to update to 966. Should I since it is beta?
2006-07-29 10:25 AM
TomWaltz wrote:943 - that must be Hotfix 0.8, then.
I think the idea was that the MacIntel version already has Hotfox 1. Check your version number. It's probably closer to 966 than 817.
2006-07-29 10:29 AM
