2006-07-28 06:05 PM
2006-08-04 03:54 AM
Gerald wrote:Gerald,
The solution was to uninstall AC 10, take out all the other add-ons and reinstall from the install disk and then apply the patch. This happened on both of my computers.
2006-08-04 09:24 AM
Gerald wrote:Now that's tricky. As I wrote, our Hotfix installer will update all Add-Ons and Goodies shipped by Graphisoft. So, if it finds a Profiler.apx, it will try to update that, since it believes to be a Graphisoft apx. So, in the unfortunate case a third party add-on has exactly the same file name as a Graphisoft add-on, you have to remove it before patching ArchiCAD, then re-install the third party tool.
I have 3 different CadImage add-ons installed and the AC 966 patch would not install with these add-ons in the AC folder. It may be because they have the same name as the AC apx's.
2006-08-04 08:45 PM
2006-08-04 11:46 PM
gkmethy wrote:right. that's the impression i got. so why doesn't archicad have a problem loading two add-ons called "Profiler" and running them as independent commands?
