2010-09-30 08:02 PM
2010-09-30 11:40 PM
2010-10-01 04:23 AM
2010-10-01 03:29 PM
2010-10-01 09:19 PM
Link wrote:You have to install the IFC Hotfix 3427 separately. As the build number suggests, the IFC add-on special hotfix (3427) is actually a newer version than the one included in the general ArchiCAD Hotfix (3269). If you are a heavy IFC user, we do recommend to use the special IFC hotfix.
Does this 3269 hotfix for AC14, include and supersede the IFC Add-On Hotfix Preview for ArchiCAD 14 – Build 3427 or do we need to install that separately (if it hasn't yet been installed)?
Link.
2010-10-01 09:23 PM
David wrote:David,
From the ArchiCAD 13 Bug Fix List:
111491 DESIGN: Interior Elevation Ceiling Line is missing when slab is on story above.
This also needs fixing in ArchiCAD 14.
2010-10-02 03:15 PM
gkmethy wrote:Great! Thanks for posting the additional info.
Yes, it will come in the next ArchiCAD 14 Hotfix.
2010-10-04 11:42 AM
gkmethy wrote:the release notes says "all languages". So is it for all languages or not?
Dear ArchiCAD-Talkers,
We have released Hotfixes today for both ArchiCAD 13 and 14. They are currently available for INT, USA and AUS language versions through the Help menu/Check for Updates... command. Other language versions will follow soon.
2010-10-07 05:15 PM
2010-10-07 05:45 PM
gkmethy wrote:THANKS
Philippe,
We have one Hotfix file for all languages, but we do test it separately for every language, that is why it is not released at the same time through "check for updates..." . As languages are tested, we make them available one by one.
