‎2011-10-20
01:11 PM
‎2023-05-23
04:40 PM
Rubia Torres
‎2011-10-20 01:28 PM
‎2011-10-20 01:41 PM
‎2011-10-20 02:11 PM
‎2011-10-20 06:51 PM
16 megabites RAMand you meant 16 gigabytes, and
the file size is 3.6 megabitesand you also meant 3.6 gigabytes, then your just-for-fun model is pushing the limits.
‎2011-10-21 08:11 AM
‎2011-10-21 09:36 AM
‎2011-10-21 02:07 PM
zeropointreference wrote:This can help, when saving the elements as an Object, under Options select: choose Non-editable binary 3D data, as this will hard code the 3D data, so it does not need to be calculated. The library part itself will be large, but may cut the 3D generation time a lot. SEOs with curved elements (for example a site mesh with SEO roads) can take a lot of time to generate in the 3D Window, this method can help relieve the calculation load.
Or, and the gurus will have to verify this or not as I really don't know, but I think you can save the result as an object and that might take care of it.
