How can I change segment of a fill
Hi ,I try to change only a segment of a fill to make one edge of it invisible .How can I do this..I am adding caps thank you...
David Maudlin
sultanmimar:
You can use a white Line, slightly heavier than the Fill's outline pen, to cover the single edge, you may need to change the Display Order to have the Line forward of the Fill. In my standard pen set, I have a series of white pens slightly wider than my standard pen weights for these situations.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David wrote:
sultanmimar:
David
Ok thank you.
