Objects/Fills change while coping from section to plan
When i copy the section on a plan the fill colors change, it doesn't happen while coping an elevation on a plan, how can copy a section on a plan without change?
3 REPLIES 3
Dontknow
Do you mean copying a section or an elevation to a worksheet?
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
In the Model Display panel of both the Section and Elevation Settings Dialog, check the option selected for the Fill Cut Surfaces with and Fill Uncut Surfaces with fields. That may be causing this difference.
Erich
Could also be renovation filters
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
