How can i make this window?
I saw some magazines on the other day and theres some houses has a groups of narrow windows locates on a wall near the top of the ceilings, those one are used to get more sunlight to the rooms. Anyone can teach me how to make or find this in ArchiCAD library?
5 Replies 5
A picture is worth a thousand words.
There are so many ways your description can be interpreted. Please attach an image of what you seek.
I hope this help
If they are separate units just use the standard windows that best suit the purpose (awning, hopper, fixed) and adjust the size as needed. If they are to be single, mulled multi-sash units there are also parts in the library for that.
David Maudlin
alvin012:
In addition to Matthew's comment, you can use the Floor Plan Cut Plane assigned to the View to determine which level of windows appear in the wall if it is a single wall (this could also be done with stacked walls on different Stories).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks for your help
To David: i changed my signature
