How can the door be separated?
mrsneuna
how can the door be separated? can it be put together? i want to make a schedule door perfectly but instead it is a duplicate just because the door is opened in a different direction. do you know how to put it together or delete one of the schedule doors?
Operating system used: Windows 10
Jp1138
Select the fields you want to combine and tell the schedule to merge any value and list them in the same cell, for example:
ARCHICAD 29 SPA (as long as the server works)
Windows 10
Miha_M
If door orientation is not important you could just remove the door orientation list criteria.
| Archicad 4.5 - 29
Jp1138
Windows 10
Setup info provided by author
