2024-06-09 05:28 PM
why can't I press select on floor plan in the schedule door?I want to remove the opening from the door schedule
Solved! Go to Solution.
2024-06-09 11:49 PM
Question is not clear but if it has to do with the gray icons then that means that the layer for the wall where the door is inserted is either off, locked or in a hidden filter.
another Moderator
2024-06-09 11:49 PM
another Moderator
2024-06-10 02:04 AM
OK, everything has been solved, apparently the opening exceeds the story height
