ā2024-06-09 05:28 PM
why can't I press select on floor plan in the schedule door?I want to remove the opening from the door schedule
Solved! Go to Solution.
ā2024-06-09 11:49 PM
Question is not clear but if it has to do with the gray icons then that means that the layer for the wall where the door is inserted is either off, locked or in a hidden filter.
another Moderator
another Moderator
ā2024-06-10 02:04 AM
OK, everything has been solved, apparently the opening exceeds the story height
