How can you 'patch' the wall lines in plans?
I have been told that you can put a 'patch' over walls lines in plans that are not required. Is this possible?
Thanks for reading
Eduardo Rolon
Menu, Document -> Document Extras -> Create Patch.
Read the help file for more information.
Creating a patch is a last resort method/option. You should be able to control wall displays with Layer Sets first.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Thank you for your reply. I have built the walls with the polygonal tool because the existing building is a fort and the walls are very thick sometimes over a metre wide and curved, however because the heights are different around the building with domed and curved ceilings I had to build several walls. Where they meet a line occurred. I have been using AC since Jan 2010 so fairly new to it. There is probably a better solution but i am not aware of it. This work is for my Degree project. (i'm in my third and final year) I am the only student using AC in my year, So I really appreciate the help i'm getting from this forum
