2023-06-05 09:27 AM
Hi Everyone,
I am trying to figure out how and where to save the custom markers that I have made for my doors and window so that I can import them into my future projects and template. I see the option "load other window-door marker..." and would be great if anyone can help and explain how to save this custom markers and reload them into future projects as it will save me a lot of time.
I found this post which is way back from 2005 and doesn't help very much with the current version.
https://community.graphisoft.com/t5/Modeling/Door-Window-Marker/m-p/38259/thread-id/19006
Solved! Go to Solution.
2023-06-06 01:07 PM
To succeed in registering a door mark, you must first make a copy of an existing mark, adjust the parameters as desired and then be able to export.
I made a video in French that shows how to do it
She should be able to help you
https://www.youtube.com/watch?v=rRfNmwvMmNs
2023-06-05 01:31 PM
Put the marker in a folder, then add that folder to your loaded libraries via the Library Manager, then Reload & Apply (button at bottom left corner). Also add that folder to your ArchiCAD template file so the marker is available in future projects. Some users have a company library folder so they have the same custom parts available in all their projects.
David
2023-06-05 02:59 PM
Hi David,
Thank you for your response. How do I save the Marker in the first place, I can't seem to figure it out as I am still new to ArchiCAD.
2023-06-06 11:40 AM
Hello,
Your door and window marks are made from graphisoft library mark?
2023-06-06 11:57 AM - edited 2023-06-06 11:59 AM
Hello Yves,
I am using the standard D Marker 26 for Doors and W Marker 26 for Windows as seen in the photo below. I am just trying to find out how to save this marker in a template or local file on my computer to reuse it in future projects.
2023-06-06 01:07 PM
2023-06-06 02:05 PM
I am not sure what you are trying to do. The D Marker 26 is part of the Archicad Library 26, so it will be an option if that library is loaded. If you save a Favorite of a door with the marker settings, the marker settings will be saved as part of that favorite.
Thanks for adding your signature.
David
2023-06-07 02:26 AM
Hi Yves,
This is exactly what I was looking for and easy to follow. Thank you
2023-08-13 12:28 PM
Thanks!
Dear Graphisoft: Should be easier than this!
2023-09-11 10:34 AM - edited 2023-09-11 10:35 AM
Now why when you go to door settings, select the custom door/window marker you created, apply it and it gets ignored? still finding that I select the door marker i created and saved but it does not get applied properly and I still have to mess around to get it to match others.
