How do I calculate area?
I am trying to calculate an area of a polyline? Anyone know how?
3 Replies 3
Djordje
Element info palette; can be found under Windows/Palettes
Or:
Activate fill tool
In the Info box, check Show area
Hold the space bar, click on the polyline
It will get filled with a fill, and show you the area.
Use polygonal shapes, not lines - if it needs to be 2D, use empty fill instead of a polyline. If it needs to be 3D, use slab/mesh. Use surface fill for finishes fill.
And so on ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
TomWaltz
A polyline is not a closed item, so I do not believe it's area is "requestable." I think all you can query is its total length.
Fills will work, but not polylines.
Tom Waltz
TomWaltz
Djordje wrote:
Element info palette; can be found under Windows/Palettes.
.... except that the polylines "Element Information" palette only shows Layer, home story, zone boundary and length, not Area.
Tom Waltz
