How do I get my house to display correctly?
So my new house that I am designing, has the basement on top and upstairs (ground floor) on the bottom. When I change the elevations so that they are correct, then they disappear from the floor plan view.
How do make it display correctly? Please see the image attached.
Thanks,
Scott
3 Replies 3
Check your story settings by right clicking on the view tab, then check you have each floor set up to display on the correct stories.
David Maudlin
Scott:
One thing to try is to select the elements in the 3D Window, Right-click, and select "Relink Home Story" to move elements to the correct story.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks Fellas!
