How do I model a wall mounted railing
I am trying to create a railing that is mounted directly on the wall but I keep having posts even after I delete them in the railing settings.
So is there a way to do this like the attached image?
fhedberg
Try setting the posts to Invisible...
W11 Home | ArchiCAD 27 3001 AUS FULL
New to 21 & trying to do the same, but when i set posts to invisible the brackets disappear too.
How do you keep them?
Eureka, set the fixing distribution to pattern by length or divisions, the brackets stay on then.
