Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
How do I model wainscot with base trim, panels, vertical and horizontal rails and a top chair rail?
4hotshoes
Each element member needs its own profile. I need to place vertical elements where ever I need them. Is the Rail Tool the thing to use? Has anyone done this or created a video that explains how?
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
1 REPLY 1
DGSketcher
Legend
The more recent versions of AC allow the use of custom profiles in the Curtain Wall tool. From what you describe that may be a suitable option. I haven't had much reason to use the rail tool so I can't advise if it would be a workable option.
