2010-11-14 06:39 PM
2010-11-14 07:49 PM
2013-03-30 10:35 PM
2013-03-30 10:55 PM
EbenezerPG wrote:use the circle tool to get the size you need, drag that circle to your fill, select the fill, space bar click on the circle (be in the fill tool)
And if I need a circular hole? I only have options for square, rectabgular or odd shapes 😞
2013-03-31 11:35 AM
Archimamamia wrote:This what we usually do, as it seems "simpler" (we are keen to use the most used tool, so not "distract" our thinking from the target result). But remember that in the pet palette there are four buttons for a direct creation of a curved hole, beside the first one for straight lines. And with two or three clicks you can use them to make full circles.
2013-03-31 06:57 PM
rocorona wrote:well, it took me less words to explain, seems more directArchimamamia wrote:This what we usually do, as it seems "simpler" (we are keen to use the most used tool, so not "distract" our thinking from the target result). But remember that in the pet palette there are four buttons for a direct creation of a curved hole, beside the first one for straight lines. And with two or three clicks you can use them to make full circles.
