2006-12-06 09:01 PM
2006-12-06 09:06 PM
2006-12-08 05:08 PM
2006-12-08 06:01 PM
konnos wrote:What don't you like about the lines?
The thing I do is uncheck the options in the Section Line that enable it to actually appear and then draw my own section lines and copy it wherever i need it. I know, the supplied section lines are quite horrid
2006-12-16 03:46 PM
Anson wrote:
How do you create a custom section marker? I don't like the existing symbols. ideally i would like to create my own but still maintain the section options, such as drawing name and sheet names. Or at least manipulate the look of the given section marker. I know that there is a way to load a section marker but i don't know where to download them from.
2023-02-26 02:45 PM
I also want to costumize the SECTION SIGN.
I can minimize the size of the built in l sign, and I can overwrite the sign by lines saved from florplan window.
Hiere I was not able to go forward.
The base part of the GDL of the section sign call a macro
call "Section-Elevation Marker Macro" parameters all A = A,
what I can not find.
Other qeustion:
Is it possible to use two different apperance at the both end of the sign?
Or three ones regarding to the middle position?
Is sombody have his/her own sign to share it mee?
2023-02-26 03:02 PM
@Katai Istvan wrote:The base part of the GDL of the section sign call a macro
Select the macro name Section-Elevation Marker Macro (no quotes) and use the command Open Object to open the macro.
2023-02-27 04:06 PM
Thanks a lot. I was able to open the Section-Elevation Marker Macro.
I am able to midify the geometry of the signs.
I could not found when it draws the sign at the two ends of the line.
I wold like to use two diferent sign at tthe two ends.
Maybe it is not an option?
2023-02-28 09:05 AM
You might be able to use the SYMB_MIRRORED global to draw a second symbol. By default it is just used to rotate text and change the text anchor, but it could probably be used to feed a completely different symbol to the Section / Elevation Tool for when double ended markers are enabled.
Ling.
2023-02-28 03:10 PM
@Katai Istvan wrote:I could not found when it draws the sign at the two ends of the line.
In the USA Library, there is the Section Part Marker_NCS which has different symbols at each end of the line. Look through your available section markers and see if you have something similar to look at to see how it is done.
