2007-02-16 03:09 PM
2007-02-16 03:37 PM
2007-02-16 03:45 PM
TomWaltz wrote:Wierd as in different from the expected or wierd as in difficult to comprehend?
I'll be the first to say that it's a little weird
TomWaltz wrote:Well someone on the VectorWorks forum told me you couldn't achieve a system like this with the use of a database. And VectorWorks uses files, not a database.
I'm not sure what you mean "using a normal file based system"
2007-02-16 03:57 PM
Christiaan wrote:Different from the expected. In concept, it's pretty simple. Pick what layers, on what floors, and what sections/details you want. In execution, it's a lot finer than that. The thing that makes it weird is that you are dividing a 3D model and 2D drawings among multiple people, and it requires a little thought.TomWaltz wrote:Wierd as in different from the expected or wierd as in difficult to comprehend?
Archicad seems to use SQL to generate reports and such. It's all one big file and I never really thought about whether it was a file or a database. I guess it's never been relevant.TomWaltz wrote:Well someone on the VectorWorks forum told me you couldn't achieve a system like this with the use of a database. And VectorWorks uses files, not a database.
2007-02-16 04:14 PM
TomWaltz wrote:Sounds like a panacea to me. I've found working in a team on VectorWorks projects to be very restrictive, especially if you use both 2D & 3D.
Archicad seems to use SQL to generate reports and such. It's all one big file and I never really thought about whether it was a file or a database. I guess it's never been relevant.Well it's the blind leading the blind then. The crux of the discussion was that you need a database driven program and that database driven programs are expensive (something that VectorWorks currently isn't).
2007-02-16 04:25 PM
Christiaan wrote:Believe me, it's not perfect and could be better, but it does work.TomWaltz wrote:Sounds like a panacea to me. I've found working in a team on VectorWorks projects to be very restrictive, especially if you use both 2D & 3D.
2007-02-16 04:29 PM
TomWaltz wrote:Well, that would be great.
The most common divisions are more along the lines of "Interior and Exterior" or "Model-based and 2D based"
2007-02-16 04:31 PM
TomWaltz wrote:Although you could be working in another layer (or story or whatever you call them), while someone else works on the doors in all the other layers right?
It's impossible for one person to take doors and another the wall the door is in since Archicad makes the doors a part of the wall. You take the wall, you get all the doors in it.
2007-02-16 04:35 PM
Christiaan wrote:A story in Archicad is an entire floor of the building.TomWaltz wrote:Although you could be working in another layer (or story or whatever you call them), while someone else works on the doors in all the other layers right?
2007-02-16 06:18 PM
