How to Extrude in ArchiCAD ?
hi there,
i am new to ArchiCAD and could anyone please tell me how we can use extrude (as in autoCAD) in ArchiCAD.
Regards,
>>>---rd----->
14 REPLIES 14
TomWaltz
I'm not familiar with AutoCAD's Extrude command. While I can kind of guess, what does it do, and what are you trying to achieve with it? (so I can answer a little better)
Tom Waltz
hi there,
Extrude is when when we make profile in x,y plane and make solid in z or upward position.
TomWaltz
The command you are looking for is called Profiler.
You may need to install it before it runs. If you look in your Archicad installation directory, there is a folder named "Goodies." Drag that folder into the folder called "Add-ons". Re-start Archicad.
Under your Tools menu, there should now be a command called Profiler.
It works by drawing a Polyline, selecting "Profiler", then either filling out the menu that appears (basically selecting "extrude" or "revolve"), then you draw the path you want to extrude it a long.
There are some 3rd party add-ons that work much better, but this one is included in the box!
Tom Waltz
can you at least give us an example of what you want to extrude...
Petros Ioannou
Extrude is used mainlly in Autocad to create walls (as 3d faces) from a 2d polyline in plan. What exactly are you trying to achieve??
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
Dear Petros,
I have got alot of drawings in dwg (AutoCAD) format and i want ro utilize them so that i don't have trace them in archiCAD.
Another problem i am facing is that when I open dwg in ArchiCAD size changes though i am using same units in both softs
Petros Ioannou
If you want to take advantage of Archicad's capabilities (specially in walls) you have to trace them manually. There used to be a Plan to Model addon but I am not aware if it still exists and how handy it is.
As for the change of size , it could be wrong conversion settings in the DWG/DXF translator settings. Did you check it?
HTH
Petros
32 GB 2400 MHz DDR4
Aussie John
ALSO GDL has an extrude command which can be used in object making.
Cheers John
[/size]
David Maudlin
rajeshd:
Two tips:
1. If you select a tool in the Tool Box, set its default parameters for what you want the model part to be (for example set the Wall Tool to 6" thick, 8' tall, etc.), then hold down the spacebar and click on a line, a wall with the given parameters will be placed along the line. This is a way to more quickly transform lines into ArchiCAD elements.
2. When importing the dwg file, check what the Drawing Units are set to in the translator to get the correct size/scale in ArchiCAD.
There is more information about both these tips in the manuals.
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
