ā2008-11-03 09:30 PM
ā2008-11-03 10:23 PM
ā2008-11-03 10:28 PM
ā2008-11-04 12:10 AM
Dwight wrote:When control lines are above and below the moulding they keep the distances from the top & bottom of the wall fixed (7' & 1') but when when the height of the wall changes the total height of moulding (2') changes?
You need both of them to be under or over your moulding.
Move the stretching control lines appearing in the profile editor to define areas of stretch and static.
only.
Dwight wrote:What do you mean?
If the automatic merging is a problem, keep the shapes apart a smidgeon.
ā2008-11-04 12:55 AM
ā2008-11-04 01:04 AM
Dwight wrote:Thanks, that did it; But that means if a wall has a Base Board & Top Moulding as profiles one of them will be stretched regardless?
Get straight on who said what.
Your diagram shows the stretch lines directly above and below the doo-dah.
Move them both down to the plain wall somewhere below the doo-dah. That will them be the only part that will stretch....
ā2008-11-04 01:54 AM
ā2008-11-04 07:55 PM
Dwight wrote:Thanks and thanks, it did it.
No!!!!
Put the dotted lines on a plain part of the wall to constrain stretching to that part.
BETWEEN all the mouldings.
