How to add grove line in Wall
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2020-07-30
02:52 PM
‎2023-05-09
03:50 PM
Rubia Torres
I am working on a project with intensive detail. I need to add groove lines in each and every exterior wall. (See Fig 1 & 2) . This groove line is Cement-Sand Plaster.
I attached two screenshots for 2D Autocad drawing & Render.
I am planning to model the whole building with a composite profile ( excluding exterior groove/ plaster). Then, I will wrap the exterior with another complex profile to add the groove/plaster)
I need to know what would be the best way to do this kind of detail? Is this the right way to do this?
Please let me know ur idea/suggestion regarding this issue.
Sincerely
Avi Shiplu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-07-30 05:49 PM
The simplest thing would be a texture that closely mimics the grooves, although it might not give you the level of realism you're looking for.
Apart from complex profiles, have a look at Jared's "strong air" trick, and see if it works for you.
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-07-31 03:28 AM
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-07-31 07:01 AM
x 1/2" members (or whatever your equivalent is) . After it's drawn you can SEO out the grooves. Drawing beams and columns can also work, after which you SEO out the grooves.
AC26 (since AC6.0), Win10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-08-01 04:00 AM
Use a complex profile including the groves as this will work in elevation.
On this size of building the extra polygons will not slow model significantly
you can't build a line
Mac Studio
iPad Pro
iPhone
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-08-02 10:29 AM
David wrote:Dear David,
Model the wall as you would construct it.
On this size of building the extra polygons will not slow model significantlygrove.png
I know how to model this profile using a 'complex profile' but I am more concerned with the graphical representation. There is are two line types in a profile (see fig-1).
The outer line is bold and the inner lines/groove lines are lighter. Can you please suggest how can I achieve this graphical representation.
Sincerely
Avi Shiplu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-08-04 03:16 AM
This is a convention in manual drafting to show the elements at the front but is difficult Archicad.
My first option is to build the wall (as above)but unfortunately using the 'outline' option also applies the outline pen to all the grooves.
The alternative is to create a hatch pattern to show the grooves (and a matching texture) and use this as the Surface for the wall. In this way you can set the outline pen the a thick pen and the will not affect the groove.
The result is as follows:-
Hope this helps
Mac Studio
iPad Pro
iPhone
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-08-04 10:26 AM
Cheers Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-08-04 11:30 AM
How do you show a thicker pen around the projecting part od the elevation.?
Long time no see!!!
D
Mac Studio
iPad Pro
iPhone
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-08-05 12:54 AM
YOU asking me a question on how to represent something in 2D? lol Last time I had to think about this was probably over 20 years
I think unless you draw an extra line around in the Elevation it is not gonna work as the pen thickness of walls are still applied to window openings?
Tell me how it is done.
www.asmtechbase.com
