2011-01-17
10:01 AM
- last edited on
2023-05-26
11:23 AM
by
Rubia Torres
2011-01-17 02:54 PM
2011-02-10 06:51 AM
David wrote:
Kent:
Select the Curtain Wall, click on the Edit in 3D button, select the panel, open its dialog box, select one of the cw windows or doors from the Panel Type pop up list. These will be curtain wall objects, not the doors or windows used in walls. If you want to use the standard windows and doors, delete the panel, place a wall that matches the opening, then place a standard window or door.
David
