How to change home story without changing height/elevation
I've just recently upgraded to Archicad 17 and need some advice.
I would like to know how to change the home story of an element, while maintaining the elements height. Whenever I change the home story, of say a slab for example, it is taking the relative height to the home story as the reference point.
For instance, ground is 0, and level 1 at 3000, and I have a slab on ground at a height of 500. If I change the home story to level 2, the slab moves to 3500. This is convenient sometimes, but how can I make it so that I can change the home story to level 1 while keeping the slab at 500?
Thanks in advance, Jake
2 Replies 2
Eduardo Rolon
The new command is "Relink Home Story".
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Great, many thanks!
