‎2010-10-29 09:59 AM
‎2010-10-29 02:06 PM
‎2010-10-29 03:58 PM
‎2010-11-03 12:58 PM
‎2010-11-03 04:39 PM
‎2010-11-03 06:09 PM
‎2010-11-03 07:03 PM
Erika wrote:To clarify: the computer / AC never has a problem knowing which is the inside or outside of a wall. But, the user may have a touch time with some reference line offset positions. Looking at the arrows (disable cleanup) gives the direction in which the wall was "drawn", and lets you pick out the inside/outside faces.... unless the Modify Wall > Invert Direction command has been used.
As an aside, placing the reference line in the center is typically not done. It is hard for the computer to know which side is the inside or outside. There are times when laying out walls this is appropriate, but this situation does not look like such a situation.
‎2010-11-03 09:54 PM
Karl wrote:So is the Inside "drivers" Left?
Looking at the arrows (disable cleanup) gives the direction in which the wall was "drawn", and lets you pick out the inside/outside faces.... unless the Modify Wall > Invert Direction command has been used.![]()
Centerline construction is common with log walls.
‎2010-11-04 01:50 PM
‎2010-11-04 03:29 PM
