2022-12-10 05:33 PM - edited 2022-12-10 05:34 PM
Hotlink modules are placed on a master layer. This allows for overriding the visibility of all layers in the HLM but not intersection group. Is there a reason for this that I am missing?
Since elements from modules are placed on the same layers as elements in the host file - what is the best way to control the intersection of these? Specifically what is the best way to avoid the intersection of elements from a module on a hidden master layer and elements in the host file on a shown layer?
Solved! Go to Solution.
2022-12-13 01:54 AM - edited 2022-12-13 01:57 AM
Hi thesleepofreason
You could use a separate 'Master' Layer (i.e. 'Module A', 'Module B', 'Module C') to host each Module. These Layers have their own Layer Intersection Group numbers, providing complete control over whether the elements in each Module intersect with other Modules and the elements inherent in the host file.
E.g. Suppose you have wall elements placed on the 'Wall' Layer in each of the Modules and the host file. Each Module is placed into the host file on its own 'Master' Layer (i.e. 'Module A', 'Module B', 'Module C'). All Layers have the same Layer Intersection Group number '1'. All elements will intersect (regardless of the Layer's visibility). If you change one of the 'master' Layers (i.e. 'Module A') Layer Intersection Group numbers to '2', then the walls placed in that Module will no longer intersect with any of the other elements. If you change the 'Wall' Layer's Layer Intersection Group number to '3', then all walls (regardless of their 'Master' Layer), will no longer intersect with any elements placed on any other Layer, unless their Layer Intersection Group number is also set to '3'.
Hope this makes sense!
2022-12-13 10:12 AM - edited 2022-12-13 10:22 AM
Hi Brendon!
I did use a separate master layer and I did change it's intersection group number. But since I didn't want any intersection at all for the module I naturally set it to 0 - which doesn't seem to work and I must have been sloppy when testing and not used another non-active group number. Because doing that resolves the issue.
So thanks for your response which pointed this out. The new, and less important, question is why it doesn't work as expected when using 0.
Hi thesleepofreason
2022-12-13 02:09 AM - edited 2022-12-13 02:16 AM
So it uses the Layer Visibility of the element layer, but the Layer Intersection Group of the Master Layer? That would have broken my projects, so probably not what you meant...
When you say "Master" Layer, you are not talking about the Hotlink Master Layer but renaming the layers in your hotlinks to include a prefix?
2022-12-13 02:36 AM
No. I do mean the Layer(s) in your project that hosts the Module. I am suggesting instead of using only one Layer to host Modules, you use multiple ones.
2022-12-13 07:18 AM
Right. So, going back to your example, what happens if I have other walls that are on a layer with an Intersection Group of 2? Intersection Groups: Master A - 1, Wall A - 1, Wall B - 2 => Master A - 2, Wall A - 1, Wall B - 2
Ling.
Hi Brendon!
