How to create a 3d section?
How can I create a 3d section in Archicad.
Here is an example of 3d section:
5 REPLIES 5
Select the required region with the bold marquee tool then right click and Show selection/Marquee in 3D
Regards, Ede
Thank you for the reply Ede.
How can I now, get back to the "normal" (3d of the whole model) mode?
Because even though I removed my marquee tool from the floor plan, I am still getting the same 3d as it was when the marquee tool was active.
Gorazd
Right click in 3D window and select Show all . I think the standard shortcut is CTRL+F5.
Gorazd Rajh
From AC 6.5 onward, i9-14900HX, 32 GB RAM, RTX 4060, Win 11
sinceV6
you can also just go with F5 (standard to "show selection/marquee in 3d window"), and since you no longer have a marquee, it'll show you everything again.
"F5" worked like a charm.
Thank you all.
