How to create a circular railing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2018-07-12
11:59 AM
2023-05-23
06:02 PM
Rubia Torres
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-12 01:34 PM
Archicad seems to dislike full circles for a lot of tools (wall, beam, etc).
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-13 12:28 AM
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-13 03:13 AM
Ling.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-13 04:42 AM
www.asmtechbase.com
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-13 04:59 AM
Carstenem wrote:It is Archicad 19 (EDU).
Looking at his screen shot he has no railing tool, so it's an older version, hence the profile option.
There should be objects for curved railings in the standard GS library.
Also some of the seemingly straight railings may have an option to allow for a curve rather than straight.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-13 05:28 AM
The standard Railing Objects have a curved option. You can set it by the radius of your circle with the angle being 360. It cleans up nicely too, unlike the Railing AC21 Tool...
If you follow Carstenem, you will have more design freedom but you will need to do two semicircular walls with your Profile, and unless your posts are circular, you will need to rotate them to the desired angle too. Small inconveniences for extra freedom.
If you are using a wired balustrade, it may look a bit odd being circular, in which case you might want to go with Carstenem as then you can model it as continuous straight segments with posts on each corner.
Ling.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-14 11:04 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-15 05:52 AM
Ciaran777 wrote:Cadimage may help for Archicad 19 (if you can still get the downloads for that version.
Ive created a circular rail, using three different semi circles. Thanks for everyone who replied. i dont understand why its so hard to create circular objects in archicad. is it true that cadimage tools helps?circular railings.jpg
I don't know for sure though as I don't use them.
I don't have Archicad running at the moment, but you should be able to do it with one object (or 2 at the most).
What is the name of the railing object you have used.
If you have the opportunity to upgrade to Archicad 21 or 22, then you will have a new railing tool that is much more versatile (still not perfect and a little more complicated).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-16 07:22 AM
www.asmtechbase.com
