2009-11-24 10:28 PM - last edited on 2023-05-23 02:59 PM by Rubia Torres
2009-11-24 10:32 PM
2009-11-25 01:20 AM
2009-12-03 02:43 AM
2009-12-03 07:22 PM
2009-12-03 11:34 PM
R wrote:I think your assessment is correct. The bending/twisting profiles in OBJECTiVE assume a constant cross-section perpendicular to the travel path, but the trusses in this roof do not follow any consistent pattern. While you could easily set out the trusses with OBJECTiVE, I'm not sure about the connecting roof - it's quite an irregular shape. I can make something that looks similar - see attached image - but it wouldn't be strictly accurate.
I downloaded a demo version of Objective and tried to create the shape. It looks like there are not the tools to do it. Using the section type of object, I can bend in plan view to get one radius, but unless I am missing something I cannot distort the shape to match the plan. The sides remain radial based on the curve of the bend, where I need them to splay to cover the floor plan.
2009-12-04 12:45 AM
2009-12-04 12:48 AM
2009-12-04 12:52 AM
2009-12-04 12:55 AM
