‎2009-11-24
10:28 PM
‎2023-05-23
02:59 PM
Rubia Torres
‎2009-12-04 07:02 AM
R wrote:I think they probably placed the trusses and then worked out the smoothness in the field.
Dwight, your comment has validity, but this building is already built, in 1965, presumably without the use of any computer to help figure out the geometry. They must have used some kind of physical model to figure it out.
‎2009-12-04 01:28 PM
R wrote:I drew the roof using the following process:
Not strictly accurate, but not bad. It looks like you extended the roof as far as you needed to to cover everything, then trimmed it, so the section at the right end isn't strictly the same profile.
R wrote:Not really, although changing the order of operations might be easier or harder to visualise (depending on the situation). The profiles are very dynamic and pliable, so you can continue to bend, twist, cut, and rotate as required. At no stage does it become a 'dumb', static shape.
Does it matter in what order you do the bends and twists in Objective?
‎2009-12-04 01:53 PM
R wrote:The
I couldn't figure out from your instruction manual what the offset operation does. Is it of any use in this situation?
