How to create a wall that has a fill pattern in elevation
<warning>I am a new Archicad user </warning>
I am trying to create a wall (stone) that, when drawn in elevation, shows a graphic stone pattern.
The wall tool does not seem to allow me to associate a pattern to a 2d elevation.
Is there an easy way to do this?
I have been playing around in GDL but I'm not sure which angle to start on. Do I try and extend the wall tool, do I create a wall extension.... what are my options?
any help is appreciated.
rondari
4 REPLIES 4
You need to assign a 3D Hatch to the Material of the Wall in the '3D Hatching' Panel of the Options\Materials Dialog.
Also, in the 'Model Effects' panel of the Section/Elevation Settings Dialog, check the Vectorial 3D Hatching checkbox.
Laszlo
Paul King
Mentor
Yes, but how do you assign a different pen to hatch than is used by wall?
Hatch should appear faint, wall edges strong.
A big problem!
Cheers
Paul
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-28 | Twinmotion 2024
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
A big problem!
Cheers
Paul
No problem at all! Look at the Material Setting DBX. Under 3D hatching you can set your pen.
Richard
AC26 (since AC6.0), Win10
Paul King
Mentor
Thank you!! I had forgotten all about that separate setting.
Would be great if you could control penweights of elements within elements own dialogue !
Cheers
Paul
