How to display Multi-viewports at the Sametime
Hi all,
I am wondering is there anyway we can display multi-viewports at the same time? Say, When I am showing the 3D I also want another 3 viewports showing plan, elevation and section. Is it possible to do this in ArchiCAD?
Thanks for any suggestion,
Jack
The Viewpoints are usually maximized. In the upper right corner you can see the maximize button. Below that is the maximize button of the Viewpoint, which you can click to unmaximize it (this is on Windows).
Then you can arrange the Windows, e. g. a Floor Plan, a 3D, a Section, etc.
However, these Windows update only when they are activated. So they do not work like in some other applications that a change made in one of these Windows is immediately updated in all other Windows.
Thanks laszlonagy
