‎2009-08-10
12:57 AM
‎2023-05-23
04:53 PM
Rubia Torres
‎2009-08-10 01:32 AM
‎2009-08-10 08:27 AM
‎2009-08-10 09:29 AM
henein wrote:Hi,
Ok, thanks. Do I save it like an ojbect or do I have to built directly on the houes? All angles on the roof of the dormer does it a little bit complicated for me as well as the the inside adaptation of the house.
/Henrik
‎2009-08-10 02:35 PM
‎2009-08-10 11:50 PM
‎2009-08-11 01:48 AM
henein wrote:Hi Henrik,
Ok. As you can se from the attached picture i tried to build my own dormer. At the moment the walls from the dormer go inside the house through the roof. How do I trim the walls so they will be exactly 34 degree like the roof?
‎2009-08-11 09:24 AM
Peter wrote:henein wrote:Hi Henrik,
Place some more roofs in position above the dormer walls, then use SEO to trim the walls to the roofs.
To use SEO (Solid Element Operations) activate the SEO palette, then in the 3d window select only the dormer walls and press 'Get Target Elements'. Now select only the roofs and press 'Get Operator Elements'. Choose 'Subtraction with Upwards Extrusion' from the list of possible operation, then press 'Execute' to trim. If the roofs are deleted the walls will return to their original height.
Using SEO has the advantage of being able to change the height or pitch of the roofs and the walls will continue to be trimmed to the underside. Using the alternative 'Trim to Roof' function will create a static trim that doesn't self-adjust if the roof moves.
‎2009-08-13 06:12 PM
‎2009-08-13 06:39 PM
