Thursday
Hi there, I am using base cabinet blocks in elelevation. Please tell me how I would add a specific opening type for the drawer (i want the opening line to be a slash (image 2).
The green shows the base cabinet object I would like to put a slash through.
This is what I want it to look like:
Is there a way to make this happen within the object settings or can I somehow edit the object to make the opening lines look like this for drawers? Help/.
Solved! Go to Solution.
Thursday
Have a look at all of the different knob options...
Thursday
I use a seperate custom 2D object to do all of the opening lines and annotation...
Editting the object would be rather complicated as there are a few layers of macros that you would need to filter through.
Ling.
Thursday
Ok, thank you, I will use that method.
Another question - is there a way to add finger pull to these cabinets?
Thursday
