How to extend X & Y and still have same size on my frame?
Ivo Skibola
I have created a window in a GDL object and saved it as a window, the frame around the glass is 50mm, in total the window is 1000x1000mm.
When I change X & Y to 2000x2000mm the frame becomes 100mm, is there anyone who can help me with my problem?
1 REPLY 1
runxel
Hero
Resizing objects made from basic elements in the floor plan will always result in scaling of everything involved. To have the frame staying the same you would need to properly script it.
POSIWID – The Purpose Of a System Is What It Does /// Ā«Furthermore, I consider that Carth... yearly releases must be destroyedĀ»
