2008-02-04 10:03 PM
2008-02-04 10:15 PM
2008-02-04 10:20 PM
2008-02-05 01:37 AM
Rick wrote:Unfortunately, that's your only option, Rick.
Yeah, but it only works for that file. Each additional file requires the same thing. I have probably opened 6 or 7 different file today. I have hundreds, and if I have to uncheck it for all of them, I am going to be pissssed.
2008-02-05 01:40 AM
2008-02-05 01:44 AM
2008-02-05 01:47 AM
Link wrote:I probably had 3 or 4 running. Not sure which panel you are referring to? I did with what I ran across. In the manager the remove is dimmed. It should be on the screen shot.
Rick -
Did you uncheck the ! warning, then click the Remove selected Add-On button?
And did you have justoneversion of AC running when you did it?
Link.
2008-02-05 01:59 AM
2008-02-05 07:50 PM
