How to hatch materials in section
I'm having trouble hatching materials in archicad 12. I want to hatch glass, steel, and soil elements in my sections but I can't figure out how to do that. Can anyone please help?
10 REPLIES 10
Erika Epstein
Select the section(s) markers
Open up its settings cmd/ctrl+T
Model Display>Uncut Elements>Vectorial 3D Hatching
Check it.
Please press the profile tab and add here your AC version and OS.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Vectorial 3D hatching is checked but nothing shows up in the drawing still
Erika Epstein
Are you using a material that has a vectorial Hatching applied to it? If not, open the material you want, make a copy of it and choose a vectorial hatch.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
I did as you said but I have no hatchings to choose from...there are no hatching types, just air space and fill percentages...
Rod Jurich
smartgurl911 wrote:
/..... no hatchings to choose from...
there are no hatching types, /.......
You may want to check your available cut fills.
Rod Jurich
that box is already checked. I unchecked it then re-checked it but still nothing.
David Larrew
One more thing to check is the settings in the actual "Section Settings" dialog...
Be sure that "Uniform Pens for Cut Elements" is unchecked under "Cut Elements" in the "Model Display" tab.
If checked, this option overrides the individual element cut appearance settings.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
the "uniform pen for cut elements" is UNchecked...but it still doesn't help, thank you though
Erika Epstein
smartgurl,
Why don't you post a screenshot of your settings?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
